Komatsu FD20 t-11 Transmission Pressure
Hi
Does anyone have any info on pressure readings for the transmsission on a.
komatsu
fd20 T-11
Serial. 4462XX ?
Thanks
  • Posted 11 Jan 2009 13:29
  • By JERRY
  • joined 10 Jan'09 - 1 message
  • Cortes, Honduras
Generally, Main and directional clutch pressures should be between 150 to 170 psi. Lube oil pressure around 15-20psi, Torque converter pressure about 45-60psi. Engine rpm should be 1100-1200.
Check pressures warm, raise and block drive wheels.
  • Posted 29 Jan 2009 02:03
  • By gearman
  • joined 29 Jan'09 - 1 message
