komatsu fb15 mg -2r steering
any thoughts, have 3 wheel with stiff steering , have changed pump unit as priority valve fails on this model( also affects tilt though) , linked out pressure switch to run pump all time still stiff to start and at limits , appears to be no parameter for slow pump speed, if use hyd function to speed pump is ok , suspect steer orbital at steer column any one had similar ?
  • Posted 7 Mar 2012 05:45
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
monday is the longest day
is the steering free? I have had bearings fail in steer units which create stiff or locked up steering.
  • Posted 7 Mar 2012 06:58
  • By bing098
  • joined 2 Mar'12 - 40 messages
  • Kent, United Kingdom
Nagano NUL120-6
Taylor TX330S
USD159,500
Muncie, IN, United States
