Cat Lift Trucks (& Caterpillar) C5000:
knock in motor
as engine idles you can here a slight pecking noise at center of engine on cam side, doesn't get harder with acceleration just faster. Checked and adjusted valve clearance. No change.
ENGINE FAMILY : NISSAN, 6NSXB02.548C, 2.5.
  • Posted 16 Jun 2015 07:12
  • Discussion started by Prancer
berwinten@msn.com
what did you set valve clearance at?
manual says 0.38mm (0.0150in) (hot)
what oil are you running in engine?
manual says to use API service classification SJ or above
SAE 10W-30.
if you meet all those qualifications then i would check the oil delivery to the rocker arm assy and make sure it is getting enough oil up there.
if oil is ok there then remove rocker arm assy and check for wear on any of the rockers and valve stems and also cam.
  • Posted 25 Apr 2016 06:55
  • Reply by swoop223
Johnston, IA, United States
Jefferson, WI, United States
St. Louis, MO, United States
