Jungheinrich ETVQ 25 Year: 1989
Need wiring diagram of it (workshop manual) Is slow driving Battery is not reach out, battery on right place The Snail button is working but the truck still slow drive
Need wiring diagram to search the problem There is A print mounted Below the Seat room Near Drive and pump motor
Need info for fix the problem
All info and help are welcome
Kindly regards
John
  • Posted 25 Oct 2013 06:30
  • By johngen
  • NB, Netherlands
Hi John,
Titus and Trev are right. Try the sensor first they do give problems, usually causing the machine to drive in slow mode.
The display is a seven segment display. The designations are as follows the top segment is "a" and moving clockwise each segment thereafter follows the alphabet, i.e. b, c etc. If there is a fault look at this display and make a note of which segments are lit. I should have list of the fault codes relating to the display.
Hi John, Yes, I have the list with a description for the codes on the display, it's only a paper copy. Do you have a fax no. and I'll send, otherwise I'll have to scan and email which will take awhile.
  • Posted 25 Oct 2013 22:48
  • Modified 25 Oct 2013 23:31 by poster
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
Hi John,
Had a good hunt around my garage for info found some incomplete notes, Trev B I think is on the right track as I recall the battery lock down pin assy against the driver side bulk head at the base of the seat box dose operate a switch assy and they do give trouble. I think it's more of an adjustment problem some part of the linkage becomes worn, I think you need the battery out and the foot plate up, as I recall I always thought it was a bit of an arkward job to sort.
Also on this truck I believe there is a fault code indicator on the micro pulse board in the form of a window when things are ok a figure 8 is displayed in the form of straight lines with a Decimal point (.) at the bottom right hand corner. When a fault is displayed the point is not present and the figure 8 is incomplete ie if a figure 2 is displayed then the probable cause is direction switch or wiring. Check to see if you have a fault code displayed.
Regards Titus
  • Posted 25 Oct 2013 21:18
  • By Titus
  • joined 6 Jul'10 - 185 messages
Hello trevb
Controller 516F is mounted Thanks.
all info are welcome
Regards
John.
  • Posted 25 Oct 2013 17:29
  • By johngen
  • NB, Netherlands
what type of controller is it, have some old info somewhere, seem to remember roller switch at bottom of battery by lock unit has n/o n/c contacts think one works light other gives full speed
  • Posted 25 Oct 2013 06:59
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Board member, UKMHA
