jungheinrich ETM 216 code 27
Not sure on the model number but by the operator's manual I found online, the code coincides with this model. The serial number of the machine is 91043337. That was the only number on the capacity plate.
I'm getting a code "027 STEER ANGLE" when I start up the machine. The steering looks for center and faults. I see that the unit has a proximity sensor on the drive housing. Its LED is not lit no matter what I do (even took it out, started the machine and moved a screwdriver in front of it. No reaction). I traced the harness back to the computer under the dashboard. All 3 wires tested good. I'm pretty sure the proximity sensor is dead.
Anyone have a manual or a better explanation of the code than what I have found in the operator's manual?
Also, the sticker was ripped off the proximity sensor. I can usually order these locally if I had the specs (NPN or PNP, voltage, etc) or if someone has the part number for it that would be awesome.
Thanks!
  • Posted 14 Mar 2013 12:27
  • Modified 14 Mar 2013 12:28 by poster
  • By justinm
Hi justinm,
Please check all the sensor signal of Actual steering angle (underside):
1- Check the proximity steering sensor in front of the traction motor : if it is still ON when touch to the metal ?
2- Check the bearing sensor/encoder inside the steering motor and change the new one.
Good luck
Nuna
  • Posted 26 Mar 2013 15:10
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
Muncie, IN, United States
Noblelift
Deborah Baker Deborah Baker
Manitou MH25-4
JLG G12-55A
