jungheinrich ere120
fault code c16 e45 truck just stops needs reset have swopped tiller head thought was fault on panic button , was ok for a week now returned ? fault codes or ideas please
  • Posted 16 Feb 2012 07:00
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
will check them thanks for advice
  • Posted 25 Feb 2012 06:56
  • By trevb
Check motor cables for shorts or bare spots , check chassis voltage. Depending on the year of truck, there was an issue where a ribbon cable inside motor controller was coming loose, you would have to remove cover to inspect
  • Posted 24 Feb 2012 00:42
  • By radon
  • joined 28 Sep'11 - 62 messages
just happens at any time direction etc have unplugged everything seems to go for a while then couple of days comes back?
  • Posted 23 Feb 2012 06:12
  • By trevb
monday is the longest day
How often does this code come up, does it happen when truck jarred? Could be motor speed sensor or motor controller.
  • Posted 21 Feb 2012 01:38
  • By radon
hi friends no power steering , unplugged everything and refitted now have c16 e19 only very occasionaly truck stops dead could it be control head cable break ? ta
  • Posted 17 Feb 2012 16:45
  • By trevb
Like nacsand inquired, this code relates to steering. Check steer sensor, too many pulses from sensor or possible noise interference.
  • Posted 17 Feb 2012 03:23
  • By radon
Has the pallet truck electric steering?
  • Posted 16 Feb 2012 09:50
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Zhejiang UN Forklift Co., Ltd
Deborah Baker Deborah Baker
