Issue with Cargo BT Series 12 Forklift
I am experiencing an issue with my Cargo BT Series 12 forklift. The forklift is unable to move forward, although the forks can still be maneuvered.
The error codes displayed are:
* When a gear is engaged: 26 56 89
* In neutral: 88 56
When I raise and lower the forks, the error codes clear and I am able to move the forklift forward and backward.
Do you have any idea what might be causing this problem?
Thank you for your assistance.
Best regards,
  • Posted 17 Jun 2024 07:29
  • By Loris
  • joined 17 Jun'24 - 1 message
  • France
Loris
26 remote input (drive): starting sequence: direction switch and accelerator should be in neutral. Maybe a switch is incorrect adjusted.
56 remote input (lift): starting sequence: a switch of the hydraulic levers is closed
89 forw+back both directions selected at the same time?
88 incorrect start sequence. check switch related to potentiometer of lift lever
  • Posted 21 Jun 2024 22:50
  • By frits_f
  • joined 19 Dec'09 - 320 messages
  • utrechte, Netherlands
