Intermittent Travel
Machine has intermittent travel, sometimes when you start the machine and select a direction, the accelerator pedal is dead. machine will not rev up and will not move. Checked the brake switches, replaced the throttle position sensor, ( this was worse) re-installed old sensor and it is now working but may still be intermittent.
Does the throttle potentiometer need to be calibrated??
Can this be done with out a laptop connection?
Second issue is the glow plug indicator is on but the machine is a VW propane engine, any Ideas?
Third, engine runs on after the key is turned off, it appears to run until the fuel runs out after the cutoff solenoid. Any Thoughts???
Thank you in advance for your suggestions
  • Posted 8 May 2014 16:50
  • By Wajaxed
  • joined 16 Feb'10 - 23 messages
  • British Columbia, Canada
If it wasn't for human error and negligence, I would have nothing to do most days.
Stay safe
Ed
The Serial number is H2X391000093
  • Posted 12 Jul 2015 08:39
  • By Wajaxed
Stay safe
Ed
I used to look after some 2008 model year 392 & 394 Linde with VW LPG engines, I remember having to replace the complete gas shut off valve assembly on 1 of the trucks as it failed. When I spoke to Linde the part had been upgraded / modified due to known failure issues since my trucks had been built.
When the shut off failed the glow plug warning light stuck on.
  • Posted 12 Jul 2015 04:37
  • By Forkingabout
  • england, United Kingdom
Glow plug may just be telling you that motor takes to long to shut down. Take the lock off apart and clean it. (Take coil off and then use 17mm wrench to unscrew shaft and inside is a piston that gets gummed up, pay attention to which way piston comes out
  • Posted 12 Jul 2015 00:06
  • By edward_m
  • joined 11 May'15 - 111 messages
Please advice the serial No
  • Posted 9 May 2014 23:45
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
SMV (Konecranes) 20-1200B
UN Forklift FD35T
edition #1280 - 7 May 2026
In this week’s Forkliftaction News , it’s financial reporting season with Hyster-Yale, KION Group and Konecranes all reporting revenue falls for Q1, yet maintaining their forecasts for moderate growth and stable sales volumes for the year... Continue reading
REPOWERTEK Inc
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
