Intermittent Stalling
Truck idles great and runs great Starts great Starts great even after stalling. stalls like you have tuned it off.
Only will stall when you are driving.. You can have it running and steer it to end of stroke and is okay
Very intermiient
  • Posted 22 Mar 2011 06:57
  • By rich_k
  • joined 30 Oct'07 - 108 messages
Is your unit equipped with an engine safety shut down system?
(two round relays and a small timer module). you said you changed ignitor but didn't mention coil or pick up. since it's impco it's probably not fuel related. what i would do is jump the distributor (black w/orange or black w/red) in a safe and interruptable way and drive the **** out of it. if it doesnt die it's an ignition voltage interuption. if it does it's in the distributor (probably)
  • Posted 2 Apr 2011 12:19
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
Hey there Toyzilla, I have tried a new ignitor in distributor , new key switch , new solenoid in starting system and new impco lock off and regulator. still stalling out. Anybodies help would be greatly appreciated Thanks
  • Posted 2 Apr 2011 06:15
  • By rich_k
Thanks I tried that. It doesnt bog down. I think the valves are fine. I am not sure where to go next. thanks again
  • Posted 22 Mar 2011 09:25
  • By rich_k
does it do this after long runs? put it in gear, hold the brake, put it in gear and hold at governor speed. if it dies let me know.
  • Posted 22 Mar 2011 08:42
  • By toyzilla
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Nagano NUZ090D
Toyota 8FD30
Singapore
USD18,000
Powerfleet
AI-enabled safety and compliance solutions for material handling operations.
Cortney Hunt Cortney Hunt
COO, Intelligrated, Trew and Transnorm
Automation manager, N.C. Nielsen
