Raymond 7400:
intermettent display
hi does anyone knows or encountered this kind of problem. lift trucks moves fine hydraulic functions are good but sometimes their is no display. i am working for a 7400 and FA model raymond reachtruck.
any suggestions would be great..thank you in advance!
best regards!
  • Posted 21 Nov 2010 03:05
  • Discussion started by forkliftcity
  • cebu, Philippines
don't bite the hands that feed you!
Battery casement short to the frame insert to negative battery cable your tester and with the positive side of tester scroll around the frame and battery and see discharge varies 2 to 6 volts surges
  • Posted 8 Oct 2015 13:12
  • Reply by edwin_q
Eddie Rod #1
  • Reply by edwin_q
Eddie Rod #1
Check the static strap, shorts to frame and volts to frame. If all are ok, check the connections at the display and fuse relay board.
  • Posted 21 Nov 2010 04:36
  • Reply by joe_d
Ain't nothing I can't fix but a broken heart and the break of day!
edition #1228 - 1 May 2025
