Install lift gate
So for this particular order picker is special. So special I had to write about it. So the problem truck is having is that on the display reads "install lift gate"
No functions other than steer and horn available.
Lift is not equipped with lift gate and had been running fine..
I checked wires behind operator compartment and could smell burn on one of the connectors
The way it's set up makes me wonder if it needs some kind of software update. Not quite sure why it says to install lift gate.... Any suggestions would be greatly appreciated
No codes present
  • Posted 29 Sep 2022 08:19
  • By Martin562Ca
  • joined 29 Sep'22 - 1 message
Mc
Check the battery box for proc sensors at the battery retaining plates. Also check the pallet clamp and see if one is installed there. Verify all the wiring looks good and the sensors should light up with switch on. May need to adjust switch. Good Luck
  • Posted 1 Oct 2022 01:10
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
VETTER Industrie GmbH
edition #1276 - 9 April 2026
In this week’s Forkliftaction News , we continue our coverage of LogiMAT 2026 held in Stuttgart with a rundown of some of the biggest product launches at the event which achieved record exhibitor and visitor numbers... Continue reading
Giant dragonfly-like insects existed before dinosaurs and were known as "griffinflies". They lived around 317-247 million years ago and had wingspans of up to 71 cm (28 in).
