Improper Lift Operation
We have a Daewoo GC30s. The first stage will full travel to the top before the second stage begins to move upward just as it should, when there is no load on the forks. However, when lifting a load the second stage will begin to move upward almost immediately with first stage, then telescope upward to full travel. Our operators are complaining about having trouble controlling the down function of the forks when placing a load on our storage racks approx. 8-10 feet above floor level.
  • Posted 16 Feb 2018 21:36
  • By jalm
  • joined 16 Feb'18 - 5 messages
  • Minnesota, United States
Thank you for the info. I have the cylinder out and will check what you suggest. I'll post an update Monday evening.
  • Posted 18 Feb 2018 21:19
  • By jalm
Sounds like a hydraulic mistage issue which was common with older Daewoo/Doosan freelift cylinders. if no other causes are apparent a reseal of freelift cylinder and replacement of staging/check valve in bottom of freelift cylinder piston will resolve your problem.
  • Posted 18 Feb 2018 12:43
  • By tom_p
  • Alberta, Canada
Thanks for the Tip!! I,ll check them out. Appreciate the help.
  • Posted 17 Feb 2018 05:12
  • By jalm
That could be a bad roller bearing in the fork carriage. With no load, lift the forks about 3 feet, shut off machine, go around and lift up on the fork tips and see if the carriage is very loose in the channels.
  • Posted 17 Feb 2018 04:14
Hawker Powersource, Inc.
The term "Spring", referring to the season, originated in the 14th century as "Springing time", describing how plants "spring" or burst into life after winter. In the 16th century "Springing time" was shortened to just "spring" for the season of new growth.
Johan Leveque Johan Leveque
Vice-chair, ALICE - (Alliance for Logistics Innovation through Collaboration in Europe)
Co-CEO, LIS Logistische Informationssysteme (LIS)
Regional sales manager, Battery Builders
SVP business solutions for the Americas, Dematic
edition #1268 - 12 February 2026
In this week’s Forkliftaction News we look at the life and legacy of Manitou Group’s Marcel Braud, who has passed away aged 93... Continue reading
