Hyster w/GM 3.0 flywheel problem
Guys:
I've been having serious problems with the flywheel in a Hyster model S50XM with serial D187V24545Z fitted with a GM 3.0. I have broken teeth on flywheel and stater. Replaced it 4 times now, but problem persists. I installed a bracethat that holds the starter much better than without it, but problem still persists. Any help will be appreciated.
Regards,
OB1
  • Posted 15 Dec 2011 11:01
  • By ob1kenobi
  • joined 22 Nov'10 - 153 messages
  • SAN P.SULA, Honduras
Cheers!
Extremely valuable information, guys. My sincerest thanks to you all!
Regards,
OB1
  • Posted 17 Dec 2011 08:31
  • By ob1kenobi
Cheers!
Also used Jungheinrich TFGxxBK / CK of GM engines
SUBJECT: STARTER KICKBACK on GM 3.0L and Mazda 2.0L
Description
The Above units fitted with the subject engines can sometimes experience starter kickback. It has
been found that this can be caused by electrical noise from the truck which signals the distributor to
fire prematurely. If this happens on the GM engine there is a possibility that the nose cone on the
starter can get broken. The nose cone on the Mazda starter is not affected but premature firing can
cause the engine to kickback and prevent starting.
A Delay Timer Kit 1465935 has been introduced which can be incorporated in the ignition circuit to
delay the distributor firing to the coil and ensures the flywheel is rotating before the electrical pulse
occurs. The kit consists of a delay timer, connectors, and installation instructions.
F-B-00025 (E)
H2.00-3.20XM
H177
S2.00-3.00XM
D187
JULY 02
  • Posted 16 Dec 2011 03:23
  • By geroj
  • joined 21 Feb'10 - 262 messages
  • Krivan, Slovakia
Check with your local Hyster dealer they offer a time delay kit that prevents kick back from the engine which damages the fly wheel and starter.
  • Posted 16 Dec 2011 02:26
  • By scot_s
  • joined 10 Jun'04 - 63 messages
  • Michigan, United States
Check the volts directly to the starter contacts?
Especially the ground. minus pole
  • Posted 16 Dec 2011 02:19
  • By geroj
  • Krivan, Slovakia
UN Forklift FGL35T
Taylor X550M
Muncie, IN, United States
UN Forklift FGL35T
Taylor X550M
