Hyster S30FT E010 No Start - Code 522598-4
I have a Hyster S30FT E010 that wont start. It is an '07 that has the Mazda with the Spectrum EPR reg. Primary pressure changes every time I crank the engine and the range is between 3.5 to 17psi. The pressure will hold steady while cranking and wont change until I turn off the key and try to start again. Code 522598-4 is in the fault log but not on display. Anyone know what that code is?
  • Posted 4 Feb 2014 07:01
  • Modified 11 Feb 2014 04:59 by poster
  • By IndLift
  • joined 19 Dec'10 - 7 messages
  • Utah, United States
Thanks for everyone's help. Turned out that the EPR was bad. With a good one, the primary pressure stays at 3.5 psi all the time and never fluctuates.
  • Posted 11 Feb 2014 04:57
  • By IndLift
Hey friend
You got my mail.
Couple helpful hints.
I do not have more
  • Posted 8 Feb 2014 02:48
  • By geroj
  • joined 21 Feb'10 - 262 messages
  • Krivan, Slovakia
Did you check the diaphragm in the mixer for a tear? Usually this will cause a no start symptom and also a pressure fluctuation.
  • Posted 7 Feb 2014 11:46
  • By Mr. Twister
  • joined 1 Apr'12 - 12 messages
  • New Jersey, United States
Does anyone have a service manual for this truck?
  • Posted 5 Feb 2014 12:31
  • By IndLift
indliftservices-at-gmail-dot-com
I must have turned the key on with the lockoff disconnected to cause the code. I had the lockoff off of the reg to test it and its OK.
  • Posted 4 Feb 2014 11:20
  • By IndLift
Code indicates the lock off voltage is oorl. You may not be getting power to the lock-off solenoid.
  • Posted 4 Feb 2014 10:29
  • By meliftman
  • joined 31 Jan'12 - 209 messages
  • Alabama, United States
Liftman
Retired
Elberta, Al.
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Tacoma, WA, United States
Highland, IL, United States
Orlando area, United States
Dallas, TX or Lexington, KY, United States
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
