Hyster J1.8XNT
Has anyone had issues with calibrating the lift speed on a Hyster J1.8XNT?
Had new hydraulic control unit fitted as the original had failed but the lift speed will not ramp up, replaced lift sensor on valve, tried multiple times to calibrate through the dash but still the same.
We did get it to work correctly a couple of times but as soon as you turn the truck off and on again it reverts back to being slow, also tried another known good unit but its still the same.
  • Posted 20 Apr 2023 20:16
  • By mrLifter
  • joined 9 May'10 - 53 messages
There are two different controllers available for these trucks. The controllers look the same but are different inside The part number may be just one number different. You need to have the same as removed or the truck will require a software update.
  • Posted 29 Apr 2023 21:51
  • By fltandy
  • joined 10 Dec'14 - 5 messages
  • CHESHIRE, United Kingdom
Is there any fault code appear in the dashboard?
  • Posted 29 Apr 2023 02:35
  • By mohamed_m
  • joined 16 Jan'15 - 63 messages
  • cairo, Egypt
mmoner1@yahoo.com
JLG G12-55A
Taylor TX330S
USD159,500
Muncie, IN, United States
