Take the floor plate off and look at the petal. Are there hoses or wires going to it.
there is no serial number plate think it go taken off to be painted and never put back on I will look at it or I can take pictures how do I tell if its fluid drive or electronic
whats the s,no. maybe an older one with fluid fed pedal. orings fail in the pedal and cause this fault
CHECK MICRO SWITCH ON PARK BRAKE LEVER
this thing may even have a push button (or other type if someone replaced the OEM) switch on the dash that supplies power to the foot pedal switches that puts the unit "in driving mode"
There are switches under the gas petal that must operate properly to make the transmission work. I would check to see if there is power going to them, the wires are connected ok, and that they are working. Also check the transmission fluid.
