Raymond 415-C30TT:
Hydraulic problems
Hi guys
I have a Raymond 415-C30TT 415-12-34535 with hydraulic problems.
The pump lift begins to heat, and afterwards the whole system hydraulic is heated. Tilt cilynder heat and stop working.
I already changed, lift pump, pistons and still the same.
That problem will have?
  • Posted 25 Mar 2014 10:40
  • Discussion started by Dany
  • Baja California, Mexico
Dany Ramos
already changed some valves. I you say that can be with residues valve box?
I'll wash the manifould and change the hydraulic oil AW46 to AW32.
Or do I recommend?
  • Posted 27 Mar 2014 01:18
  • Reply by Dany
you have a restriction. Is it not slow to lift? Load holding valve, prop valve stuck. Start pulling them out, check for filings or dirt
  • Posted 26 Mar 2014 11:42
  • Reply by EasiTek
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
Terberg YT220
Wellwit WMF1000
Shenzhen, Guangdong, China
USD50,000
