Hydraulic Manifold Issues
So we just put a new manifold into a 2012 model. Hooked everything up and now our problem is that we cannot get the forks to come down. Every other function works (tilt, forks in/out, slide left/right) the only way we can get the forks down is if we actuate another lever and then push the lever on the forks, or if we hit the gas pedal and rev up the RPM's then push the lever to bring the forks down. We checked the solenoid below the fuse panel. We have 12v there when you actuate the lever and you can hear it working but we have nothing.
  • Posted 30 Jan 2016 00:50
  • By bollinmi
  • joined 30 Jan'16 - 3 messages
Try spinning the lift spool 180 and see if that helps. I know that issue was around on some Clarks.
  • Posted 30 Jan 2016 03:56
  • By Adams1
  • joined 24 Jun'15 - 61 messages
  • Indiana, United States
