How to reduce the speed of Jungheinrich truck EJE118-2008
Dear all Jungheinrich experts,
My customer is using the truck model EJE118 (Pallet truck - AC Technology - 2008). Due to the truck is running to fast so they ask me to reduce to the lower speed. Please help me to check and advise how to reduce it without service cable. Please note that this truck has only the LCD display for the battery, there is no keypad or any anythings else for adjust.
  • Posted 31 Jan 2012 14:18
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
Yes, i have programmed with keypad, in fact, if you want to program operator codes the keypad is the only way to program. Its not the easiest to do, its difficult to see what your programming. Keypad 0-9 with a 'set' and 'O' buttons. Becareful when you order, there are two different can bus systems out, keypads look the same but will not work. You have to enter a 4 digit maintenance code, then know all the parameter numbers to enter into keypad, its alot of button pushing to accomplish.
  • Posted 1 Feb 2012 07:03
  • By radon
  • joined 28 Sep'11 - 62 messages
Hi Radon.
Have you tried to program this lifter with keypad? And if, is it the small 10 digit "unlock keyboard"? I've heard that AC's only can be programmed by JUDIT, but i'm not sure if there is another way.
Regards, Max
  • Posted 1 Feb 2012 05:38
  • By Fittermax
  • joined 17 Jul'08 - 171 messages
  • Denmark
If your not a Jungheinrich dealer, you could purchase the keypad to wire in and program that way since you have the lcd display. Its not so cheap though. They also offer a programmer to plug in, all that in amounts to is the keypad with an LCD display, again not so cheap, but if your not a dealer you wont have the ability to get Judit for your laptop
  • Posted 1 Feb 2012 02:16
  • By radon
HI Nuna.
You need a laptop with JUDIT to change parameters.
Regards, MAX
  • Posted 31 Jan 2012 20:30
  • By Fittermax
  • Denmark
Hi Nuna
Just try to change the potentiometer i think?
  • Posted 31 Jan 2012 18:26
  • By stillengineer03
  • joined 4 Nov'10 - 47 messages
  • Singapore, Singapore
George Peter
georgepeter03 at gmail dot com
Hoist Liftruck P360-48
Terberg RT223
Terberg RT223
Muncie, IN, United States
Deborah Baker Deborah Baker
