Hyster H2.5FT:
Hour Meter editing
Hello, need to swap VSM and Display to other truck, how to edit hour's on VSM or Display to old values? As I know after change in one of them it could be transfered via Reprogam tool.
  • Posted 18 Jan 2022 18:34
  • Discussion started by Tomas_Gerulis
  • Lithuania
Fishmech,
Serial number mismatch will be if i will change jsut one of them, but i will change both, that will be ok, i just need to change hour meters.
Tomas,
If you are swapping both for test purpose, hours will follow the VSM and Display. The hours cannot be changed from one lift to another, you will get a serial number mismatch if you try. Sorry.
  • Posted 22 Jan 2022 03:39
  • Reply by Fishmech
  • Virginia, United States
Jefferson, WI, United States
St. Louis, MO, United States
Johnston, IA, United States
