HORN CONTACT PIN
does anyone have the part # for the horn contact pin for a caterpillar gc20k serial # AT82C-00864 thanks in advance
  • Posted 28 Jul 2016 04:23
  • By jsanchez89
  • joined 26 May'16 - 29 messages
  • Illinois, United States
thank you for all your help swoop223 i appreciate it
  • Posted 11 Aug 2016 21:11
  • By jsanchez89
oil pressure switch is MD138993
  • Posted 11 Aug 2016 13:21
sorry swoop forgot to thank you for your help with the contact pin works great now. by any chance do you know the part number for the oil pressure switch light came on the other day thanks again
  • Posted 11 Aug 2016 04:21
  • By jsanchez89
there are actually some other parts that may be needed to repair the horn properly, just replacing the plunger and spring may not be enough to make it last.
As adams1 said you will need:
9135142600 - plunger
9135405600 - spring, earth
You may also need:
9135408900 - carbon washer
9135402400 - plate, contact
9125501800 - spring, horn
9135403100 - plate, set
9135402500 - packing
Now although you might can get by just replacing the plunger and earth spring i have had many of these where the contact plates are worn out and even after cleaning them up they still did not want to work properly, usually you can get by not replacing the plates. The spring, horn may be ok as well, just use the old one unless it is corroded. The packing is just the rubber seal around the button area.
Now... the most important part in these other parts i've listed is this carbon washer, mcfa came out with a hpk service gram recommending to add this carbon washer under the steer wheel, between the steer wheel and top contact plate ring on the steer column. This carbon washer is the new conductive surface for the plunger to ride on instead of the brass ring on top of the steering column, there is a considerable reduction on wear on the plunger when installing this carbon washer so you will not be replacing it every few months like what was happening before then.
So i would at least recommend getting the carbon washer kit also when you replace the plunger and earth spring.
  • Posted 28 Jul 2016 22:14
9135412600...plunger 9135405600....spring
  • Posted 28 Jul 2016 20:19
  • By Adams1
  • joined 24 Jun'15 - 61 messages
  • Indiana, United States
Tampa Florida, United States
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
