Help! P02 traction transistors keep blowing
I'm hoping someone can help. I'm getting pump trouble 012 initially then when I try to drive it jumps forward and does and displays traction trouble 011. 3 codes: 512,513 and 517. It blows one of the traction transistors when it jumps forward. I've checked all 4 diodes, checked drive motor and cables for shorts. No contractors are welded... any ideas??
  • Posted 5 Jun 2020 06:50
  • By Turbolarry
  • joined 5 Oct'19 - 11 messages
I dug out alot of battery corrosion when I checked cables but it was clean when I popped the last 2 new transistors. The customer has a really good weekly cleaning/watering schedule. All the batteries look new but there was alot underneath the battery pan
  • Posted 17 Jul 2020 02:10
  • By Turbolarry
By any chance is the battery super corroded and has acid everywhere? I had a truck that had so much surface voltage it would cause shorts, until I ran the truck with the battery on the floor!
  • Posted 17 Jul 2020 00:13
  • By MarcoMontana
  • joined 8 Jan'13 - 11 messages
Yes, both diode blocks removed and disconnected. I ran the drive motor using by-pass and the directional contactors. The drive motor runs great. I also ran the hydraulic motor successfully.
I just got done checking the integrity of the insulation sheet under both transistor heat sinks. Ran 200volts (handyman) no leaks. I've decided to send this girl to the shop. Crazy
  • Posted 16 Jul 2020 23:03
  • By Turbolarry
Really? The Selftest only closes contactors and looks for shorts it does send any amps through the system. This tells me you have a direct hard short!
You tested the diodes disconnected yes? Also of course you ensured they are 1 directions only?
Run the test with the traction Fuse out, see if it blows any thing, if it doesn't you know the issues is in the traction circuit!
  • Posted 16 Jul 2020 22:55
  • By MarcoMontana
Thank you Marco. I've checked just about everything. I ran both the hydraulic and drive motors. I've checked all 4 diodes (both blocks) with a Handyman. Checked all contractors and sent the main card out for testing and repair. I checked all power cables. The only thing that hasn't been checked yet is the rubber insulation sheet under the transistors. I mean I checked the heat sink for short to chassis with an ohm meter, but not with the Handyman. I know Clark's use to get pin holes in that sheet causing shorts. This thing is definitely a problem child. But thank you for chiming in. I already burnt up 2 new transistors. They blow on the self diagnostic check.
  • Posted 16 Jul 2020 08:40
  • Modified 16 Jul 2020 08:41 by poster
  • By Turbolarry
Nissans with this system are know to pop Transistor when a load is on them that is not normal, like pushing pallets of beer across the warehouse. I have replaced so many panels and transistors its crazy!
If you are drawing massive amperage through the system with maybe a bad battery, or even a bad Motor, The field windings of the motor or the armature, commutator all of these are potential issues. 012 being PS pump motor code first are the brushes welded to the commutator?
You have a massive draw or short in the system the power cables running through the frame and under the battery I would check first.
Diagnostic mode: Hold 1 & 4 turn key on, push 3
To run self diagnostic
Hold 1 & 4 turn key on, Put in Forward, and push 1
Programming: Use on board system with dash display
Hold 1 & 3 and turn key on
Also don't forget the normally closed side of the Directional Contactors, the 1A , and flyback contactor.
One other thing is the main speed board in the back that covers the contactors, if that touches one of the contactor bars because someone pushed on the back door or whatever it will blow the board and the transistors immediately.
  • Posted 16 Jul 2020 07:03
  • By MarcoMontana
Yup I have the manual. Thanks
  • Posted 7 Jun 2020 04:22
  • By Turbolarry
Just check anything you can check, sometimes power goes throw all different parts of controller.
Do you have a manual?
  • Posted 6 Jun 2020 23:43
  • By John50
  • joined 7 Sep'19 - 155 messages
  • Netherlands
You mean the IGBT modules? Those are for the power steering aren't they?
  • Posted 6 Jun 2020 23:33
  • By Turbolarry
  • Posted 6 Jun 2020 23:32
  • By Turbolarry
You better check all RGBT modules and transistors
  • Posted 6 Jun 2020 22:08
  • Modified 6 Jun 2020 22:09 by poster
  • By John50
  • Netherlands
I just thought of something. I bet that hole entire panel is mounted on a rubber sheet. I wonder if its shorted to the frame
  • Posted 5 Jun 2020 21:04
  • By Turbolarry
No, I wish it was that easy. 400plus amp traction transistor keeps blowing. A card (I dont think) cant do that. Thanks for responding
  • Posted 5 Jun 2020 11:45
  • By Turbolarry
Possible fault on logic card?
  • Posted 5 Jun 2020 07:17
  • By elektrodrive
  • joined 2 May'08 - 752 messages
enquiries@elektrodrive.co.uk
Taylor TT300
USD98,500
Terberg TT223
VETTER Forks, Inc.
edition #1285 - 11 June 2026
