Yale GLP050VXEVSE:
HELP FAULT CODE 524230-30
Can anyone help me w/ fault code, Yale forklift, code: 524230-30. SN B875B17788F.
Best Regards!
Gabriel
  • Posted 24 Mar 2012 04:10
  • Discussion started by gabriel_p
  • nuevo leon, Mexico
'Vivere militare est', Seneca.
Did you happen to remember what fixed this issue?
  • Posted 26 Jun 2018 09:17
  • Reply by forktime
  • Alberta, Canada
Gabriel can you fix this problem? I have the same fault. I have the same fault.
  • Posted 26 Oct 2016 14:37
  • Modified 27 Oct 2016 10:46 by poster
  • Reply by jesus_v
  • Not Applicable, Mexico
THANKS TITUS, I'LL TRY.
REGARDS!
  • Posted 3 Apr 2012 04:38
  • Reply by gabriel_p
Tail mark driver out put is to low check all rear lighting and change any that are not working these units are LED units now also you can now get a soft wear update to put onto your VSM so that your engine keeps running when a light fails, but ypu will have to get aYale engineer to install it.
Regards Titus
  • Posted 27 Mar 2012 03:22
  • Reply by Titus
Thanks Titus. The right code is 524230-3, not -30, but I have change the relays and the engine shutdown in 30sec after start it. I have tested the relays too. Also another equipment SN B875V01909F marks the code 882-4, any idea abut this?
Regards.
  • Posted 25 Mar 2012 03:27
  • Modified 25 Mar 2012 03:30 by poster
Hi Gabriel,
I think the problem lies in the Power disribution box code referes to rear work lamp relay being defective, the relay is RL7 maybe you can swop it with another relay and check to see if rear work lamp is working.
Regards Titus
  • Posted 24 Mar 2012 18:44
  • Reply by Titus
edition #1235 - 19 June 2025
