head gasket failure
Mistsibishi engine 4FG64.
We are having a rash of head gaskets fail,We have planned the head /Block
Head is in Thickness size.
New head bolts.
Correct torque to yeild specs.
Looks like Antifreeze eating gasket?
We are using OEM gaskets ,
has any one run into this before.
All these engines are in daewoo units.
  • Posted 4 Jun 2007 23:45
  • Discussion started by pacfork
  • British Columbia, Canada
We did find out what was causing the problem?
The compression was to high 230lbs.
If we planed the head it made a majour impact on the compression ratio,we even had the machine shop port out the head to lower the comp rate. Changed very little.
Even with a new head and measureing the block thickness we still had high comp.
We also think that when the engines were manufactured they took to much of the block too get the block deck flat.
We were able to get the comp down to 176 lbs by putting in two head gaskets and a head saver shim between.040"
Yes it is mickey mouse but next step was to buy a new engine.
  • Posted 25 Oct 2007 14:01
  • Reply by pacfork
We had a number of headgaskets seem to of had several issues from improper headbolts to a passage in the head not open.Once a head was removed if a mechanic used an a high speed air disc it caused an uneven deck surface?Still the dealer/manufacturer was unsure?
  • Posted 25 Oct 2007 09:03
  • Reply by jerry_o
Are you using any CopperCoat or High-Tach adhesive when installing the gasket?
Did you re-torque the head bolts,after running the engine to operating tempature?
  • Posted 6 Jun 2007 13:27
  • Modified 6 Jun 2007 13:30 by poster
  • Reply by Truck_Tech
  • United States
  • Posted 6 Jun 2007 06:19
  • Modified 6 Jun 2007 06:20 by poster
  • Reply by Toric
  • lothian, United Kingdom
SMV (Konecranes) 4531CC5
Elwell-Parker ESI500-36
edition #1234 - 12 June 2025
Yale GDP100M
Flesherton, Ontario, Canada
UN Forklift FBR25NQC3
Your Focus
