Having some major issues with this truck
This truck was out it the rain via delivery and was turned on to take off truck like an idiot. It now has a code 45 when first started and will not function at all. Any help would be appreciated. Thank you in advanced.
  • Posted 21 Nov 2012 08:10
  • By marvin_g
  • joined 21 Feb'11 - 25 messages
  • Kentucky, United States
i say let it dry out
bet the code goes away
  • Posted 22 Nov 2012 20:47
Code 45 - PC Contactor Detected Open When Commanded
Closed
Does the contactor pull in for a second on startup? check the fuses (sometimes the fuses can be blown but test good, but once load is applied to them they open, i usually put vise grips across them, for a small period to test them, if they check good with a meter but suspect a fuse) Check the contact tips make sure they are good. It most likely smoked a bunch of cards/q1 rec etc... and at that point its best to call in the stealership, as if you start buying cards and putting them in, and if another card/component is shorted may fry the new card right away and you won't get warrenty on the card, as where if its the deal they can do some creative warrenty work. But you may get lucky and is just a fuse or arched contact tips.
  • Posted 22 Nov 2012 06:49
  • By patrick_b
  • joined 10 Dec'11 - 30 messages
  • Alberta, Canada
UN Forklift FD40T
Crown CG33P5
edition #1237 - 3 July 2025
Saratoga, United States
East Syracuse, United States
Columbia, SC, United States
UN Forklift FBR25NQC3
Terberg YT222
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
