Hard starting
I have the said model unit it is very hard to start I am getting fuel to the rail and injectors but it doesn't seem to have much pressure to it I can however shoot a little bit of starting fluid to it and it will start and stay running. Any ideas.
  • Posted 15 Mar 2019 02:43
  • By Paps
  • joined 15 Mar'19 - 16 messages
Ok that is a good start. That would be a issue no doubt. it could be sucking air if its bad or if its equipped with a check valve it could be bad maybe. thank you for getting back with me. we will look into this. have a great day.
  • Posted 15 Apr 2020 23:41
  • By keith_m
  • joined 29 Jun'09 - 57 messages
keith@kmcequipment.com
Yes I did it was in the primer pump behind the batteries
We replaced it and put a new filter on it bled out the system. Truck is running great now with no start issues.
Found out that this is a common problem with these trucks.
  • Posted 15 Apr 2020 23:34
  • By Paps
Did you get to the bottom of why this unit is hard to start. we have one that seems to have the same problem Tier 4 engine. Extremely hard to start , but when it does it runs absolutely fine. once you shut the engine off and let sit even for 10 seconds its back to a very long hard start. its acting like a check valve of some sort is not holding back pressure on the system. I'm trying to get some service info on this unit.
  • Posted 15 Apr 2020 23:21
  • By keith_m
It sounds like the fuel is leaking off. I would start by checking the fuel lift pump. Not sure what it looks like on your truck. There is normally a check valve in the lift pump or in the hand pump if it has one.
  • Posted 16 Mar 2019 04:53
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
Sorry this is a diesel unit not LP
  • Posted 16 Mar 2019 00:36
  • By Paps
Sounds like there is tar build up in system. May need to drain regulator and clean injectors.
  • Posted 15 Mar 2019 23:34
  • By BREWSKI
UN Forklift FGL18T
Still GX10
Still GX10 2000
Poland
EUR950
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
UN Forklift FGL18T
Still GX10
Still GX10 2000
Poland
EUR950
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
