Hyster H155FT:
fwd/rev switch open, no transmission, but no codes
replaced switch, replaced DSC due to some small cracks and some moisture in it. There are no DTC set. Still same problem. Checked sister truck and i can check switch operation through DSC with parking brake on/off, person in or out of seat, service brake on or off. That leads me to believe the problem is not the seat switch, parking brake, or service inching etc. No fuses blown.
  • Posted 30 Sep 2020 10:39
  • Modified 30 Sep 2020 10:40 by poster
  • Discussion started by ricky_j
Rick.rapidlift@gmail.com
pls do u have the hyster pc tool for diagnostics?......in cases like this it helps because u access the system
  • Posted 17 Oct 2020 04:41
  • Reply by northstar
  • accra, Ghana
When replacing the DSC did you check to make sure that the option for the the direction control was set to the left side switch on the DSC?
  • Posted 17 Oct 2020 04:22
  • Reply by LCNIII
Johnston, IA, United States
Jefferson, WI, United States
St. Louis, MO, United States
