Fwd / Rev Cuts out Under Load
Checked all of the common problems. looking for any advice good or bad.
Has full volts at contact coil buts still disconnects. Negative cuts out. Trucks has allot of hours. Drive Motor has been checked. Battery good.
  • Posted 21 Jul 2008 23:32
  • By Prentice
Pull both cards out of panel and check them with a magnifying glass. Look for corrosion and solder cracks. This will cause intermittent problems.
Also, what is the battery voltage holding up to under load. Put the unit in lift or tilt bypass and check voltage at panel. Low voltage will do strange things.
  • Posted 26 Oct 2008 03:21
  • By NissanFixer
  • joined 26 Oct'08 - 1 message
  • Michigan, United States
i dont know about this truck in particular but
how old is it
is there codes?
what system is it?
have you checked all the coil snubber assemblies?
do any other contactors drop out under load? (pump, line? if so equipped)
is the current limit set too low?
do the f&r contacts drop out when you deadhead the pump while driving?
do they kick back in when the load is removed? or do you have to fully release the pedal or reset the key?
check for voltage drop from neg of the contact coil to battery negative should be minimal when contacts are engaged
clean all the plugs
also clean heavy cable connections with a wire brush
what do you mean by a "load" bulldozing (pushing) loads across the floor can load trucks past the limit
toyotas fry their IGBTs when bulldozing on occasion
  • Posted 22 Jul 2008 12:27
  • By justinm
September confidence index jumps Fort Collins, CO, United States
ROYPOW
The term 'Genuine Leather' is not used to reassure you that the product is made of leather, but rather to indicate that the lowest quality of leather is used.
October 28, 2026 - Melbourne, Victoria, Australia
November 3-6, 2026 - Shanghai, China
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Toyota 8FD30
Singapore
USD18,000
Terberg RT223
Tommi Haavisto Tommi Haavisto
Director of sales, EMEA & APAC, Hiab and MOFFETT Truck Mounted Forklifts
Regional director for UK & Ireland, TVH
President - business area port solutions, Konecranes
President, Logisnext Europe
