Forward takeoff is too fast/jerky
Just bought this lift with 2200hrs and the forward pedal is a nightmare. When I press the forward pedal nothing happens for a quite a distance of pedal travel. You hear the engine speed up slightly then suddenly it grabs and takes off. It takes off slow but not slow enough to creep up on a pallet rack without crashing into it. The reverse pedal is great and its super smooth. You can make the lift back up extremely slow.
Any ideas? Is there something that I can adjust?
  • Posted 7 Jan 2015 10:23
  • By JoeFox
  • joined 7 Jan'15 - 4 messages
  • Louisiana, United States
Thanks I will give it a shot.
  • Posted 10 Jan 2015 02:36
  • By JoeFox
I think you may have the problem with the symmetry adjustment of the drive transmitter. The adjustment may be done by turning the rear and front bushing (in travel direction) of the transmitter device.
It's not so easy to descibe it without drawings.
The drive transmitter - it' the black box on the top/rear of the front axle.
I has two valves stretching on sides and the small axle linked with the lever towards the back of the truck. There are (on the axle) the bushings to be adjusted.
Good luck
  • Posted 9 Jan 2015 23:04
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
Model: H35T-03
SN: H2X351N0688935
  • Posted 9 Jan 2015 08:57
  • By JoeFox
Do you have a serial number for the truck?
  • Posted 9 Jan 2015 03:24
  • By little_forker
  • joined 31 Jul'11 - 82 messages
Hangcha FLDCXT160
SMV (Konecranes) 4545CCX5
