Forward & reverse inoperable
Looking for help with a Cat DP50K 2 speed transmission that will not go into forward or reverse; the backup alarm works with the engine running and when the transmission is shifted into reverse. Haven't noticed any abnormal noises. Any help would be appreciated, thank you.
  • Posted 24 May 2011 04:00
  • By cownd
  • Arizona, United States
orchidlane29@gmail.com
Thanks for the reply; after digging further I checked and had voltage to the directional soliniod with 150 psi pump pressure with 150 psi fwd/rev pressure and proper inching valve operation with a pressure gauge. After checking all that I removed both drive axles and found the left axle in 6 pieces. Was able to retrieve all the pieces (I hope) and ordered a new axle. I'm going to try to drain and clean the diff as well as I can; any suggestions on cleaning the diff? Thanks again for the reply.
  • Posted 24 May 2011 08:56
  • By cownd
the backup alarm is/should be on a seperate circuit from the circuit that provides the drive signal
how about a serial number, and letting us know if this unit has a working seat switch?
  • Posted 24 May 2011 08:43
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
Taylor TE650S
Toyota 02-8FD25
Tommi Haavisto Tommi Haavisto
Director of sales, EMEA & APAC, Hiab and MOFFETT Truck Mounted Forklifts
Regional director for UK & Ireland, TVH
President - business area port solutions, Konecranes
President, Logisnext Europe
Taylor TE650S
Toyota 02-8FD25
The term 'Genuine Leather' is not used to reassure you that the product is made of leather, but rather to indicate that the lowest quality of leather is used.
