forks won't move: lift,tilt. nothing
the forks don't move at all. when lever is used all you hear is a click, can someone please help. email is mariofl at baptisthealth dot net.
thank you
  • Posted 23 Mar 2010 11:15
  • By mariolop
  • joined 23 Mar'10 - 1 message
sounds like fuse, contact tips or main lift motor brushes. take the rear cover off and check the large fuses for continuity. if fuses are ok you can remove 1 motor cable and check continuity from one lug to the other. both tests should read close to 0 ohms or very low resistance. if you dont have knowledge of meter use let me know and i will get more in depth and give you some alternatives via email.
  • Posted 23 Mar 2010 12:01
  • By rick_c
  • joined 30 Jul'09 - 204 messages
technology: (no user serviceable parts inside)
