Forklift won't move, inching valve?
Hello guys
I'm just a simple mechanic from Belgium who has a small home shop if you can call it that way. I have a Nissan EH01A15U small forklift, I believe early 90s.
It started with having no reverse. Some fidling with the shifter linkage seemed to do the job. The next day I had reverse nor forward. A lot shifting (and the engine warming up?) later it worked again but I decided to change the transfluid and clean the filter. After this it still worked, but today again no movement. In the short period I had the Nissan I always had to give some revs until it broke free as to speak.
After some searching it seems like the culprit could be the inching/declutch valve, I have 2 brake pedals. The left pedal moves a pivoting arm on top of the trans, about 90 degrees. When disconected I feel no resistance at all in this arm.
Any advice? I'll probably will need to remove the top of the trans?
  • Posted 29 Jul 2018 06:33
  • By flash
  • joined 29 Jul'18 - 1 message
  • Belgium
HI
TRY REMOVING THE CONTROL VALVE AND CHECKING THE SPRINGS HAVE YOU PUT A TEST GAUGE ON THE VALVE
  • Posted 18 Dec 2019 23:02
  • By Mark_Jones
  • joined 18 Dec'19 - 2 messages
  • Hertfordshire, United Kingdom
MARK
Taylor T520S
UN Forklift FD25T-C2JM1
VETTER Industrie GmbH
Taylor T520S
Taylor T520S
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
