Forklift Safety Cage
Hello all,
I'm new to this community. I work for a food manufacturer in the San Francisco bay area and we are currently looking to purchase a a safety cage for use in our facility. I saw a few online but most are sold by companies outside of the U.S. Perhaps I'm not searching correctly. We'd be content with something used as long as it's integrity is intact. Any suggestions or leads?
thanks
Sivan
  • Posted 24 Oct 2007 05:04
  • Discussion started by sivan_w
sivan w:
Google: FORKLIFT WORK PLATFORMS and you should find several U.S. manufacturers.
Ensure the work platform you choose meets ANSI/ITSDF specifications.
  • Posted 1 Nov 2007 11:03
  • Modified 1 Nov 2007 11:04 by poster
  • Reply by joseph_h
  • Michigan, United States
sivan w:
Google: ITSDF.ORG for a free copy of ANSI/ITSDF B56.1-2005, Safety Standard for Low Lift and High Lift Trucks courtesy of the Industrial Truck Standards Development Foundation.
You should review:
4.2 Modifications, Nameplates, Markings, and Capacity (all) especially 4.2.3: "If the truck is equipped with a front-end attachment(s), including fork extensions, the user shall see that the truck is marked to identify the attachment(s), show the weight of the truck and attachment combination, and show the capacity of the truck with attachment(s) at maximum elevation with the load laterally centered )," ITSDF
4.17 Elevating Personnel (all) especially 4.17.3 (o): "The combined weight of the platform, load, and personnel is not to exceed one-half of the capacity as indicated on the nameplate of the truck on which the platform is used." ITSDF
7.37 Platforms: Elevating (all) especially 7.37.4 (b): "Hydraulic or pneumatic hoisting systems shall include means to prevent unintended descent in excess of 0.6 m/s in event of a hose failure." ITSDF
If you are considering the work platform for normal production order picking, you may want to consider an order picker type truck which only requires one operator and is designed to perform such activity.
  • Posted 30 Oct 2007 22:06
  • Modified 30 Oct 2007 22:08 by poster
  • Reply by joseph_h
Small items (S.I.)=non full capacity loads (N.F.C.L.) LOl
Apparently, many forklift have overhead guards that are rated at 16,000 ft-lbs. A pallet falling from 8' high, the OHG's strength would support 2000lbs.=small item.
Towmotor definitely wins out. And all those who use the term towmotor don't even know that Towmotor was a forklift brand.
  • Posted 30 Oct 2007 09:47
  • Reply by dan_m
A safey cage is a platform, equipped with guard rails, required to elevate a person.
An overhead guard is a grill-like structure which is incorporated into the lift trucks, to prevent small items from striking an operator.
When the proper terminology is used, it definitely avoids confusion!
  • Posted 30 Oct 2007 03:27
  • Reply by dan_m
Hi all
Two points: The guard abve the driver in almost all cases is not a rollover guard (the mast prevents rolovers occurring) but a guard to prevent injury from falling objects when the forklift is being operated at height. In some cases people should review the guard from a safety perspective. And the tinned food industry is one of those. Can a heavy 1 kg or more tin fall from a pallet, especially in the pre-cartin stage, and through openings in the overhead guard. If so you need to install some mesh or acrylic sheet to remove that risk. I appreciate than numbers of manufactrurers have acrylic inserts/sheet that prevent any objects getting through the guard.
And the workcage: Buy one that complies with the ISO or other standards - but also read the standards and make yourself aware of the other requirements when workcages are being used. For example ISO / Australlian standards require:
For counterbalance forklifts the lated capacity of the forklift must be 1800 kg or 5 times the total weight of the workcage, plus workers, plus tools and other materials. And for reach truck the figures are 1000 kg or three times;
THe mast tilt control must be mechanically locked out;
The driver must stay at his post for the full time prople are in the cage; et cetera
So its not just the design of the workcage that is the issue
  • Posted 27 Oct 2007 10:58
  • Reply by John_Lambert
  • Victoria, Australia
Better to strive and experience all life's colours from pain to ecstasy than to exist in a grey life
yes, etharp, you're correct. I didn't make it very clear but we're looking for the fork add-on cage , not the driver's cage.
But thank you Dangerous for reiterating to us all the safety hazards associated with aftermarket alterations tot he driver's cage.
  • Posted 26 Oct 2007 08:21
  • Reply by sivan_w
Please for Safety sake do not consider going down this track.
Retro fiting a guard to a forklift is a minefield & an area you should think about seriously before you go there.
Manufactures supply canopies / guards as a standard part after roll testing.
By retro fitting a guard to any unit you are assuming the obligations & responsibilities of the manufacturer.
Realize that you can be held responsible in the event of an accident.
I suggest you contact the manufacturer & change your plans before you invite personal litigation.
  • Posted 26 Oct 2007 05:11
  • Reply by DANGEROUS
  • Queensland, Australia
"OUR BUSINESS IS SAFETY"
Give me a call and I'll send you a quote for our new forklift work platform/safety cage. Full featured and secure. HD and fully galvanized for the food industry. 281-992-2006, Houston, TX
  • Posted 25 Oct 2007 23:20
  • Reply by BrianS
SMV (Konecranes) 16-900C
Hangcha CBD15
China
USD1,600
