Forklift only moves at normal speed when turning sharply
The forklift when moving straight forward or backwards or when turning only slightly moves extremely slowly and jerks a little, almost as if the battery is nearly dead or perhaps the brake is not releasing fully. It takes about 8-10 seconds to go a foot even when fresh off the charger and there is a faint buzzing noise that I don't recall it making when it was working normally. However when making a sharp turn in either direction the forklift quickly accelerates to its normal full speed both forwards and backwards and continues to go at that speed until you start to straighten out. When you're turning and going normal speed and start to straighten out it slows down immediately like you slammed on the brakes and goes back to the jerky barely moving thing it does. Anyone have any ideas on what might be causing this?
  • Posted 11 Jan 2018 08:14
  • By kainoa
  • joined 11 Jan'18 - 1 message
  • Hawaii, United States
Could have sworn it said RC3020...my bad
  • Posted 22 Jan 2018 14:10
  • By Ifixit
Ifixit....the unit the OP is asking about is an RC5500 series.
You may need to rethink and edit if you are attempting to offer advice.
  • Posted 22 Jan 2018 13:26
  • By Buster_Hymen
  • joined 21 Jan'18 - 16 messages
Could be 2 reasons. First, the steer switches are not working. They turn off the inside motor by opening the contactor circuit. The unlikely reason is the drive motor (or both motors) are shorting to each other. Raise and block both front wheels off of the floor and check to see if each motor turns off left and right while turning the steer wheels
  • Posted 18 Jan 2018 12:02
  • By Ifixit
September 9-11, 2026 - Hanoie, Vietnam
September 16-17, 2026 - London, United Kingdom
edition #1294 - 13 August 2026
In this week’s Forkliftaction News, we report on Jungheinrich’s H1 financial results and the reasons it has adjusted down its EBIT forecast for the year... Continue reading
