Forklift moving very slow, Events 365, 343 ,304
Hello , i have a problem with a forklift Crown WP 3020 , it`s moving very slow , both in forward and back. There are 3 event codes present : 365 ,343 ,304
I have swapped the controller with another one from a working forklift, but the problem is the same. Can the motor be damaged?
I don`t have the manual ,so i don`t know that the codes mean...
  • Posted 12 Feb 2016 20:57
  • By ct10dre
  • joined 12 Feb'16 - 3 messages
  • constanta, Romania
Often it is a temperature sensor but is there anyone who knows the part number
  • Posted 15 Nov 2024 21:57
  • By Emad_Omara
  • joined 26 Sep'22 - 5 messages
  • Saudi Arabia
Emad omara
The WT is nothing like the WP at all WP uses Curtis controller WP uses zapi. has it got electronic steering???? It does make a big difference to the codes. Fixed or folding platform????. The code I would look at first is the 304, check and clean the estop does the dash turn off when you isolate the truck as it has a micro switch on the bottom the fails all the time. Strip and clean the main switch they are prone to dirty contacts due to dust ingress finally is the battery good???? 304 is a power issue and a truck showing 304 will throw other codes as well.
  • Posted 6 Apr 2016 06:58
  • By lifter01
  • joined 4 Jul'09 - 463 messages
Strange I don't have a listing for WT here in Canada -from what I see on the web the WT is very similar to WP but has stand on platform. Wiring is a common fault for brs/ors switch harness at base of steer tiller and the temp switch is very common. Don't be shy to cut off the ties and get a good look at all the flex points of the harness. Do you know what control system is in this Curtis or Sevcon?
  • Posted 11 Mar 2016 11:25
  • By troy_m
I made a mistake , the forklift model is WT-3020.
Will the previous answer still apply?
  • Posted 14 Feb 2016 12:57
  • By ct10dre
Check that the brake switches are ok it's common on these to have cable breaks on them, also check the cables from the temperature sensor in the motor these break on the connectors. Finally check the motor encoder is good I've changed plenty of these too it's bolted into the end of the motor with an Allen bolt. Unlikely to be the motor we've nearly 50 Wp3020's on site and not changed a motor yet
  • Posted 13 Feb 2016 07:45
  • Modified 13 Feb 2016 07:46 by poster
  • By lifter01
Hoist Liftruck F180-36BOX-CAR
Mafi MT25
Mafi MT25 2008
