Toyota 7FGU45:
Flooding out
SERIAL number 60926.
Starts good. After wot while running the hydraulics engine will sputter out and stall. You can pump the trottle and may stop the engine from stalling. I removed the mixer cover and looked down the mixer. I ran it like this and when I let off the throttle you could see the LPG filling in and causing it to flood. Any ideas if the regulator could be the issue. The engine works good under medium load but will flood out after fast idle.
  • Posted 9 Jan 2018 05:35
  • Discussion started by Barfly_olaf
  • Nova Scotia, Canada
First of all, I would like to tell you to be safe from the LPG gas flooding, As it can make hazardous Fire damage at home that can disturb everything at home. I remembered a few days ago the similar problem was going on at my neighbor's home, and thus suddenly the LPG catches fire which results into the blast at home. This made them calling to the insurance company for collecting the proofs and claiming the policy. But the insurance company was delaying the fact, so they took helpful hints from the public adjusters like public adjuster Los Angeles (www.alliancepublicadjusters.com/public-adjuster-los-angeles) for taking the process ahead.
  • Posted 12 Jan 2019 23:11
  • Reply by Allensims
  • Arkansas, United States
Thanks.
It's throttle cable and air governor. I am curious about the diaphram vacuum on the back side of the mixer. 3 screws triangle shaped. No holes but curious to the purpose of it. Is it acting like a trim valve?
  • Posted 10 Jan 2018 01:41
  • Reply by Barfly_olaf
Most likely regulator issue. Especially if it's cable throttle with air governor.
  • Posted 9 Jan 2018 23:32
  • Reply by stam
Ottumwa, IA, United States
Harrisburg, SD, United States
Wentzville, MO, United States
Crown CG33P5
JLG G12-55A
Lift Technologies Inc.
edition #1235 - 19 June 2025
