fgc25n with nissan k21L no rev when warms up
I have a Mitsubishi fgc25n af82f-00263
we are having a no rev problem when the unit heats up, if you just jump on the truck and start it up it runs fine for a few minutes, 5-10 minutes later it looses power and will not rev past 1200-1500 rpm, and revs very slowly. i cleaned the afm "witch was very dirty" and cleaned out the carb. i accidently left the connector off in the process of cleaning the maf and am showing a code 21, "my fault" is there any way to reset the ecu without the laptop. ive disconnected the battery cables, touched them together, all the usual tricks, nothing seems to clear the code. i want to start fresh and see if the unit throws a code when this happens.
we just recived the unit and are preping it for sale, but cant let it leave the shop if its not right. and is there a list of codes and numbers anyware for this truck. ive searched google and you dont really find anything.
  • Posted 31 May 2008 00:17
  • By lifttruckdoctor
  • joined 25 Mar'08 - 7 messages
  • United States
I saw you reply to an old question about acceleration problems after unit warmed up and I have a similar problem. Where is the 2 wire trans temp sensor if not the one at the bottom of trans. please reply.......chopped
  • Posted 2 Mar 2012 05:33
  • By chopped
  • joined 1 Oct'11 - 7 messages
  • New Mexico, United States
well, i made a discovery,
i disconnected the trans temp sensor, 2 wire for the computer, not the idiot light sensor. revs nice and runs well. shows code 34. got the sensor coming..
  • Posted 31 May 2008 05:16
  • United States
Hangcha FLDCXT160
Tusk 500PGH16
