fault t-226
Frequently stopping no forward and reverse.what i need to change?
  • Posted 22 Apr 2015 06:10
  • By wills_b
  • joined 22 Apr'15 - 3 messages
  • doha, Qatar
Thanks,
I suspected the microswitch for forward and reverse then i changed with new microswitch only because the complete pcb board was expensive.
Fault was disappear and okay.
  • Posted 24 Apr 2015 02:55
  • By wills_b
  • doha, Qatar
Linde L16 trucks: there were different generations and types, so the serial No would be usefull.
If it's 131 series, as I presume, you have the problem either with the potentiometer or with the microswitches in the tiller head.
You should disassemble the tiller head, and you'll find the pot connected to the printed board, and the row of small switches surrounding the plastic axle.
Check them.
Eventually check the wires around.
  • Posted 23 Apr 2015 18:30
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
TCM FD80Z7
TCM FD80Z7 1990
Toyota 8FD45
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
