fault code T241
I have a Linde p60 W4191H00054 is serial number. I had switched out a bad motor to a good motor from a different lift that is being used for parts. After installing this motor it has no movement and it will give a fault code of T 241 does anyone know where I should start do I need to just start testing wires for resistance and try to find the problem
  • Posted 6 Sep 2023 02:57
  • By Pupupuputter
  • joined 6 Mar'19 - 11 messages
Check your Battery if it is grounded to body and also the 24 volts power supply.
  • Posted 9 Sep 2023 03:20
  • By Rolly
  • joined 9 Sep'23 - 1 message
  • Bahrain
have you not got the software to plug in to it?
  • Posted 7 Sep 2023 02:43
  • By andrew_k
  • joined 17 Mar'07 - 338 messages
  • England, United Kingdom
Well that didnt do it it still wont move and throws same code I think its something more major wrong with this unit
  • Posted 7 Sep 2023 02:35
  • By Pupupuputter
I will check this in the morning as it is the end of a 14hr day and I am already cleaned up but thanks for pointing me in right direction
  • Posted 6 Sep 2023 09:45
  • By Pupupuputter
Speed sensor error
  • Posted 6 Sep 2023 06:26
  • By andrew_k
Sue Tomic Sue Tomic
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Nagano NUZ090D
USD1
Nagano NUZ090D
