Fault Code H
I am working on a Cat Model 2EC15. Customer complained the forklift would not move and displayed a code H on the dash. I messed with the lift levers and the code went away. The forklift operates good now. What was the Code H for? and what could be the possible cause?
  • Posted 5 Dec 2007 09:36
  • By forkliftbob
  • joined 28 Aug'05 - 4 messages
  • Michigan, United States
Thank You, Carl. We removed the panel cover and it looked like it had never been cleaned, after air cleaning iit the problem has not come back.
  • Posted 11 Dec 2007 23:48
  • By forkliftbob
H on display at start up is one of the hydraulic switches is closed while the key switch is closed. That is probably why the code went away when you messed with the control levers. Check the control valve switch adjustments or it could have been some debris hold switch closed intermittently.
  • Posted 6 Dec 2007 09:21
  • By carl_v
  • joined 12 Oct'07 - 76 messages
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
October 13-15, 2026 - Shenzhen City, China
November 10-11, 2026 - Auckland, New Zealand
June 17, 2027 - Nottinghamshire, United Kingdom
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
