Cat Lift Trucks (& Caterpillar) M50DP:
Fault code F9
Hi we have this unit with fault code F9, main contactor engages and then disengages ?
  • Posted 3 Sep 2014 08:17
  • Discussion started by albert_g
  • Alberta, Canada
F&9 = open shunt field fuse
also could be faulty wire connections, open shunt field, shorted T351 transistor, or logics defect.
the flow chart mentions the driver board, this could also be the cause.
check connections:
check field shunt fuse, replace if open
check continuity of wire #34 from line contactor to logics P12-4, wire #71.
7 to 10 ohms? check driver board, no continuity? repair wires or connections
check driver board (field shunt components only)
not failed? replace logics
failed? replace driver board.
  • Posted 4 Sep 2014 03:40
  • Reply by swoop223
Thanks, I will look into this SER#4YJ00363
  • Posted 4 Sep 2014 00:09
  • Reply by albert_g
  • Alberta, Canada
It would help to post the serial number. I think this is a micro command system. Code F-9 could be a blown shunt field fuse. The fuse should be a small glass (10 amp ? ) located in the rear panel upper right corner. The wire number should be 34. I would look there first and inspect wiring from it. Sometimes replacing the fuse is all it takes. Post your results and let me know if you need more information to dig deeper.
  • Posted 3 Sep 2014 14:39
  • Reply by shovel_fx
  • Illinois, United States
Terberg YT182
Manitou M50-4
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
SMV (Konecranes) 25-1200B
Mobicon 2T
