Still CHARGER:
Fault Code: F6
the charger is working normal and showing the amphere level on the LED display. but after a few minutes a fault code will appear "F6" but nothing will happen. the F6 will just show up but the charger will work fine. and i dont know if it will be close automatically if the battery is full. bcoz it charge too long that i need to close it manually to prevent the battery to overcharge.
  • Posted 12 Aug 2017 19:14
  • Discussion started by justin_d
  • RIYADH, SAUDI ARABIA, Saudi Arabia
justin1404135@gmail.com
Thanks for this asnwer. it really helped me. now i know where to look at and what to fix. and yes indeed the air hose is not connected on the battery. so thats why. thanks again.
  • Posted 24 Oct 2017 23:31
  • Reply by justin_d
F6 means Air blowing system is not connected.
Air hose connection to the battery is damaged,
if the battery has no air system it is possible
to change the charging progam in the charger,
the method depends on the charger model.
Greetings
Michael
  • Posted 22 Oct 2017 06:12
  • Reply by michael1
  • Nordrhein-Westfalen, Germany
brand : Still
  • Posted 1 Oct 2017 17:09
  • Reply by justin_d
what Brand of Charger is it?
  • Posted 28 Sep 2017 04:15
  • Reply by Wongo22
  • hampshire, United Kingdom
TCM FHD105Z
Crown SX3030TT4250
Lift Tek Elecar
