Fault Code A
Hi guys,
Don't know if anyone can help, we are looking at a CAT M35D which operates fine under most circumstances, however if accelerated hard from a standing start will cut out drive and display fault code A. Hydraulic's and other systems work fine.
Does anyone know what fault code A relates to or can point us down the right route.
  • Posted 3 Apr 2012 00:14
  • By Dez_A
  • joined 3 Jun'04 - 84 messages
  • Middlesex, United Kingdom
Service life of a forklift is proportional to how well it is maintained.
Jplayer spot on, one of the terminal was burnt out on the capacitor, have replaced capacitor and all working well. Thanks, top advise is always appreciated.
  • Posted 13 Apr 2012 22:43
  • By Dez_A
Top man Jplayer, will investigate and report back.
  • Posted 3 Apr 2012 20:57
  • By Dez_A
if an "A" is displayed on the dash this indicates a "Head Capacitor" Failure.
The Head Capacitor ensures that a steady voltage is maintained to the positive headsink and that large voltage spikes are filtered out. The logics monitors this at P2-2.
Performance of the truck will be reduced when this error is active.
Check the head capacitor for any abnormalities. swelling or bad connections or improper readings during testing.
Also make sure the battery is in good condition , a low battery can cause high amp draw and might cause strange problems.
There may be other things that might cause this issue but i'd start with these things first.
  • Posted 3 Apr 2012 20:26
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
