fault code -51 nothing works
dash display says capacitors voltage too low -any ideas??
  • Posted 30 Apr 2010 03:58
  • By troy_m
this unit quit while driving and the operator said he heard a loud humming noise like a pump motor. I checked and found a contactor welded together and it opened at my touch and the code -51 disappeared. I'll replace the contactor tip kit and see how it goes. Thanks for the suggestion.
troy
  • Posted 1 May 2010 07:55
  • By troy_m
check the current limiting resiter that bridges over the line contactor. it allows a small current into your controller to pre-charge the capacitors so they can self check before startup.
  • Posted 1 May 2010 04:32
  • By kevin_k
this might help E50XM2-33 #f108V232294
  • Posted 30 Apr 2010 03:59
  • By troy_m
St. Louis, MO, United States
Evansville, IN, United States
Daleville, IN, United States
Uxbridge, Canada
edition #1236 - 26 June 2025
As June comes to a close, the month when our sector recognises National Forklift Safety Day , the United Kingdom’s Association of Industrial Truck Trainers (AITT) has issued a timely reminder of the need to ensure any staff training is fully accredited... Continue reading
