fault code 43 and no forward or reverse
I have a Cat p6000 lift. Just resently recieved. Drove when unloaded now it has no forward or reverse and get a code e-43 on dash. It did have a seat switch, removed and 3wires were wired nuted together. Came that way. Running on LP. Forks go up and down. Does run little rough. Also can any one tell me what fluids are used for hydrolic and tranny. Both are low and not sure of grade or weight fo fluid to use.
  • Posted 21 Nov 2011 11:19
  • By robb_t
  • joined 21 Nov'11 - 3 messages
  • Arizona, United States
No I have not washed it recently. But I will check the connection. I have not disconnected the solenoids either, but will check them as well. Where are they?
  • Posted 23 Nov 2011 14:04
  • By robb_t
didja wash this machine, and blow a bunch of water and crud up into the ECM connection? have you disconnected the transmission selector solenoids?
F85= Transmission forward solenoid
F87=Transmission forward solenoid speed 2
  • Posted 23 Nov 2011 09:16
update. Did a test, first cleared codes. Foot dance did not work, but disconnecting the battery negative for 5 min. did. Started it up, runs rough at idle until warm. Tried the controls and several warning lights on dash came on. Also got codes, F-85 and F-87. Forks still go up and down but no forward or reverse. 3251 hrs. on machine.
  • Posted 23 Nov 2011 01:19
  • By robb_t
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
Philadephia, PA, United States
Chandler, United States
Terberg RT223
Aichi SR18A
ROYPOW
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
