Fault Code 16
I am currently experiencing trouble with a EC3500 Forklift. When I move the forward / reverse switch into either position it will move about 3 - 5 ft and then throw fault code 16. Any help with this is appreciated.
  • Posted 19 Apr 2015 18:07
  • By camero101
  • joined 19 Apr'15 - 3 messages
Code 16 is for the traction motor stall timer. Check your wiring and connections between the drive motor, inverter and logic. I'm willing to guess you have a bad bearing encoder (speed sensor) in the drive motor.
  • Posted 22 Apr 2015 12:55
  • By JimConnected
  • joined 23 Jun'11 - 15 messages
Linde Material Handling
