Raymond 740R45TT:
Fault 2A
Intermittent code 2A along with temperature indicator. Turns on and disables lift for 5-10 seconds then starts and all is ok for many hours or days.
Is this fault for drive motor temp?
  • Posted 19 Aug 2016 02:22
  • Discussion started by tom_p
  • Alberta, Canada
Yes it is for Traction motor approaching over temp. sounds like you may have an intermittent open in the temp sensor wiring
Run Test A08 if you can access the system
  • Posted 19 Aug 2016 03:50
  • Reply by Rbarn
edition #1228 - 1 May 2025
UN Forklift FBRS15KQZ2
Enforcer FLBAXT25
