fault 245 pathfinder Linde R14 AC 2005
Hi , i have a 245 fault in a Linde AC 115 serial truck, line contactor not closed and book flash on dash. battery full and oke.
i hope you can help me
  • Posted 1 May 2014 14:45
  • Discussion started by gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Did you get this sorted we have the same problem
  • Posted 10 Feb 2025 02:47
  • Reply by paul_haggar
  • Northamptonshire, United Kingdom
weird...
thanks for the update.
  • Posted 4 May 2014 06:55
  • Reply by frits_f
  • utrechte, Netherlands
hi , i have replace LAC module , same problem. second step i replace charge resistor with the k2 and k3 relay but no effect!! With a screw driver i have shortcut the contact k1 directly after start up with ignition and problem fixed.. truck works oke and i can set it off and on and all oke. I have no idea how and what give the problem
  • Posted 3 May 2014 02:25
  • Reply by gc_d
Regards gc_d
oke thanks , i check this tomorrow and write as i find the problem
  • Posted 2 May 2014 04:49
  • Reply by gc_d
Regards gc_d
I don't have experience with this particular error on this truck. But had similar errors on a 386 model.
The manuals say check the wiring: charging circuit, etc. Could be a bad battery / bad connection/dry cell (checked that? try with an other battery!).
But probably the capacitors in the LAC are bad; charging them takes too long. I once opened a power module and found some loose soldering of the capacitors.
Oh, and I had a truck on which a working light was connected after the line contactor: it didn't start when the working lights were on.
  • Posted 2 May 2014 04:37
  • Reply by frits_f
Hi frits , i have seen this so any idea how fix this ? or only fix it with replace LAC module?
  • Posted 1 May 2014 23:32
  • Reply by gc_d
Regards gc_d
If it is a traction error : 245: LAC cannot reach 40V during charging.
You have a problem with the charging circuit that charges the capacitors directly after starting up.
  • Posted 1 May 2014 18:09
  • Reply by frits_f
GemOne
Johnston, IA, United States
St. Louis, MO, United States
Jefferson, WI, United States
edition #1234 - 12 June 2025
