Fault 12801
Good day, i am trying to figure out what the fault code 12801 is on one of our forklifts, model E50XN-33. Any help would be appreciated.
  • Posted 6 Jun 2024 02:34
  • By James_Horner
  • joined 6 Jun'24 - 1 message
James
James,
This is a problem with the directional switch. There should be about 5 volts to switch. The return goes back to VSM at different pin locations. Suspect the switch has come loose or failed. Do you have switch in lift handle, on throttle pedal or at steer column? This will help in determining the next steps to take. Good Luck
  • Posted 11 Jun 2024 04:13
  • By Fishmech
  • Virginia, United States
Toyota 02-8FD30
UN Forklift FD25T-C2JM1
