Hyster S70FT:
Fault 100-4
I have 2 Hyster S70FTs, both have a fault code of 100-4. The one runs fine but the code stays on. The other one will not start. Can anyone help with this. Our local Hyster guy was down and told us it was the oil pressure sender. We replaced the sender with no change. Thanks for any help
  • Posted 9 Jan 2013 08:13
  • Modified 9 Jan 2013 08:14 by poster
  • Discussion started by ntlifts
  • Iowa, United States
When you check the oil pressure reading the dash assembly under diagnostics, does it show a numeric value or question marks?
  • Posted 14 Apr 2016 12:42
  • Reply by manfred
did you check the power and grounds going to the sender to make sure they were ok??
  • Posted 9 Jan 2013 08:38
  • Reply by kevin_t
edition #1228 - 1 May 2025
